https://cobbtuning.zendesk.com/hc/en-us ... to-Datalog
Gauges setup - https://cobbtuning.zendesk.com/hc/en-us ... yed-Gauges
Accelerator Position
A/F Correction #1
A/F Learning #1
A/F Sensor #1 (AFR)
Battery Voltage (V)
Coolant Temperature (C)
Calculated Load
Engine Speed (rpm)
Feedback Knock Correction
Fine Learning Knock Correction
Gear Position (Gear)
Dynamic Advance Learning
Dynamic Advance Multiplier
Ignition Timimg
Injector Duty Cycle (%)
Intake Temp (C)
Intake Temp Manifold
AVCS Exhaust Left
AVCS Exhaust Right
AVCS Intake Left
AVCS Intake Right
Knock Correction Advance (degrees)
Manifold Relative Pressure
Mass Airflow (corrected)
Mass Airflow Voltage
Oil Temperature (C)
Wastegate Duty
Vehicle Speed (kph)
Throttle Position
Logging
2015+ WRX
AF Correction 1 (%)
AF Learning 1 (%)
AF Sens 1 Ratio (AFR)
AVCS Exh Right (°)
AVCS In Left (°)
Accel Position (%)
Calculated Load (g/rev)
Coolant Temp (F)
Dyn Adv Mult (DAM)
Dynamic Adv (°)
Feedback Knock (°)
Fine Knock Learn (°)
Ignition Timing (°)
Inj Duty Cycle (%)
Intake Temp (F)
Intake Temp Manifold (F)
KS Noise Cyl 1 (raw)
KS Noise Cyl 2 (raw)
KS Noise Cyl 3 (raw)
KS Noise Cyl 4 (raw)
KS Thresh Cyl 1 (raw)
KS Thresh Cyl 2 (raw)
KS Thresh Cyl 3 (raw)
KS Thresh Cyl 4 (raw)
MAF Volt (V)
Man Abs Press (psi)
Primary Ign (°)
RPM (RPM)
Throttle Pos (%)
Vehicle Speed (mph)
Wastegate Duty (%)
AF Learning 1 (%)
AVCS Exh Right (°)
AVCS In Left (°)
Accel Position (%)
Coolant Temp (F)
Dyn Adv Mult (DAM)
Dynamic Adv (°)
Feedback Knock (°)
Ignition Timing (°)
Inj Duty Cycle (%)
Intake Temp (F)
MAF Volt (V)
Man Abs Press (psi)
Primary Ign (°)
RPM (RPM)
Throttle Pos (%)
Vehicle Speed (mph)
Wastegate Duty (%)
