Logging variables
Posted: Wed May 09, 2018 3:45 pm
				Accel. Position (%)
AF Correction 1 (%)
AF Learning 1 (%)
AF Sens 1 Ratio (AFR)
AVCS In. Left (°)
AVCS In. Right (°)
Accel. Position (%)
Boost (PSI)
Calculated Load (g/rev)
Coolant Temp (° C) D
Dyn. Adv. Mult (DAM)
Dynamic Adv. (°)
Feedback Knock (°)
Fine Knock Learn (°)
Gear Position (Gear)
Ignition Timing (°)
Inj. Duty Cycle (%)
Intake Temp (° C)
MAF (g/s)
MAF Volt. (V)
Man. Abs. Press. (PSI)
RPM (RPM)
SD VE (Comm.) (%)
SD VE Est (MAF) (%)
Throttle Pos. (%)
Vehicle Speed (mph)
Wastegate Duty (%)
			AF Correction 1 (%)
AF Learning 1 (%)
AVCS In. Left (°)
AVCS In. Right (°)
Accel. Position (%)
Boost (PSI)
Dynamic Adv. (°)
Feedback Knock (°)
Ignition Timing (°)
Inj. Duty Cycle (%)
Intake Temp (° C)
MAF (g/s)
MAF Volt. (V)
RPM (RPM)
SD VE (Comm.) (%)
SD VE Est (MAF) (%)
Throttle Pos. (%)
Vehicle Speed (mph)
Wastegate Duty (%)
