Owner:PhilB
Rom: D0XJ002K
Car Weight: 1480g
Driver Weight: 200kg
Total Weight: 1680kg
Raptor headers
Cat back exhaust but appears to have std rear mufflers
Flatt racing intake pipe
PhilB - 2005 JDM Subaru Legacy 3.0R 6MT - Tuning
VaDa
Re: PhilB - 2005 JDM Subaru Legacy 3.0R 6MT - Tuning
Do you have definition in xml file for this ROM ???
Are you a tuner? What we use is not supported but Ecuflash or Romraider.
VaDa
I'm not tuner. I am the owner of the same machine model. 2006 JDM legacy Spec B 3.0R 6mt with same ROM: D0XJ002K
But I can't open that ROM with romraider.
OK. She is pinging too much?
Don't worry. I was wondering why you would need to see the rom and you maybe a complete novice.
VaDa
Yes. I am newbie. but not a completely beginner
I just want the most out of my car.
VaDa
maybe you know what I can do without see the rom ?
I did something on the car and he did not drive badly. But I want to drive even faster.
Log her using romraider and review any issues.
We offer logging/Diagnostic services to help.
http://xtremeracingtuning.com/logging-diagnostics/
http://xtremeracingtuning.com/2017/09/2 ... -flashing/
Logging variables:
Logging variables:
Accelerator Pedal Angle (%)
A/F Correction #1 (%)
A/F Correction #2 (%)
A/F Learning #1 (%)
A/F Learning #2 (%)
A/F Sensor #1 (AFR)
A/F Sensor #2 (AFR)
Coolant Temperature (C)
Engine Load (2-byte)** (g/rev)
Engine Speed (rpm)
Feedback Knock Correction (degrees)
Fine Learning Knock Correction (degrees)
Gear (Calculated)* (position)
IAM (1-byte)** (multiplier)
Ignition Total Timing (degrees)
Injector Duty Cycle (%)
Intake Air Temperature (C)
Intake VVT Advance Angle Left (degrees)
Intake VVT Advance Angle Right (degrees)
Knock Correction Advance (degrees)
Manifold Absolute Pressure (psi)
Mass Airflow (g/s)
Mass Airflow Sensor Voltage (V)
Oil Temperature (C)
Throttle Opening Angle (%)
Vehicle Speed (kph)
