What does an ECU do?
Posted: Mon Mar 10, 2008 1:39 pm
ECU operation
Control of fuel injection
For an engine with fuel injection, an ECU will determine the quantity of fuel to inject based on a number of parameters. If the throttle pedal is pressed further down, this will open the throttle body and allow more air to be pulled into the engine. The ECU will inject more fuel according to how much air is passing into the engine. If the engine has not warmed up yet, more fuel will be injected (causing the engine to run slightly 'rich' until the engine warms up).
Control of ignition timing
A spark ignition engine requires a spark to initiate combustion in the combustion chamber. An ECU can adjust the exact timing of the spark (called ignition timing) to provide better power and economy. If the ECU detects knock, a condition which is potentially destructive to engines, and "judges" it to be the result of the ignition timing being too early in the compression stroke, it will delay (retard) the timing of the spark to prevent this.
A second, more common source, cause, of knock/ping is operating the engine in too low of an RPM range for the "work" requirement of the moment. In this case the knock/ping results from the piston not being able to move downward as fast as the flame front is expanding.
But this latter mostly applies only to manual transmission equipped vehicles. The ECU controlling an automatic transmission would simply downshift the transmission were this the cause of knock/ping.
Control of variable valve timing
Some engines have Variable Valve Timing. In such an engine, the ECU controls the time in the engine cycle at which the valves open. The valves are usually opened later at higher speed than at lower speed. This can optimise the flow of air into the cylinder, increasing power and economy.
Control of starting
A relatively recent application of engine control is the use of precisely timed injection and ignition to start an engine without the use of a starter motor. Such a static-start engine would provide the efficiency and pollution-reductiton improvements of a mild hybrid-electric drive, but without the expense and complexity of an oversized starter motor.[1]
Control of starting
