Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
Posted: Sat Aug 04, 2012 7:23 pm
A nice turbo for the 2004+ JDM STI with around 400+WHP on tap. Additional mods should include Perrin EBCS, Process West TMIC, ID850 Injectors
Supporting mods should be
Part Number SUB-1.5XT-R Twin Scroll
Description
Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 470CHP
Specs
Garrett Ball bearing CHRA
56.5mm Turbine Wheel
71mm XT Compressor wheel
47lbs per min
BPT Twin Scroll Turbine housing
Turbo includes water pipes, oil feed line, and ported exhaust housing.
JDM Twinscroll header, uppipe, downpipe needed for install
- Perrin EL Header - http://www.perrinperformance.com/subaru ... pipe-combo
Perrin EBCS - http://www.perrinperformance.com/subaru ... s/ebcs-pro
Process West TMIC or FMIC - http://www.processwest.com.au/index.php ... cooler-kit | http://www.processwest.com.au/index.php ... cooler-kit
HKS Turboback Exhaust system
Kelford B Cams w/ Kelford Valve Train (KVS109-STi) -http://www.camshaftshop.com/products.php?productid=1009
Omni Power 4Bar Sensor - http://www.rallysportdirect.com/Omni-MA ... MAP-Sensor
ID1000 Injectors- http://www.injectordynamics.com/ID1000.html | http://www.rallysportdirect.com/Injecto ... eed-1000cc
Description
Horsepower: 470CHP
Specs
47lbs per min
