2015+ 3.6 Legacy/Outback
Accel. Opening Angle (%)
AF Sensor #1
Air Flow Sensor Voltage_ (V)
Ambient Temperature (BC)
Atmosphere Pressure (PSI)
Calculated Engine Load (g/s)
Coolant Temp. (BC)
Engine Speed_ (rpm)
Long term fuel trim B1 (%)
Knocking Correction (deg)
Ignition timing adv. #1 (B)
Intake Air Temp. (BC)
Learned Ignition Timing_ (deg)
Mani. Absolute Pressure (PSI)
Mass Air Flow_ (gs)
Oil Temperature (BC)
Relative Throttle Pos. (%)
Short term fuel trim B1 (%)
VVT Adv. Ang. Amount R (deg)
VVT Adv. Ang. Amount L (deg)
VVT Exh. Retard Ang. R (deg)
VVT Exh. Retard Ang. L (deg)
Vehicle Speed_ (mph)
SubaruEdit Logger
2015+ SubaruEdit 2.0/2.5i Impreza/XV/Legacy
A/F Sensor #1
Engine Load (g/rev)
Engine Speed_ (rpm)
Mass Air Flow_ (g/s)
Vehicle Speed_ (KPH)
Engine Load (g/rev)
Engine Speed_ (rpm)
2015+ WRX/Forester
Accelerator Opening Angle (%)
Advance Multiplier* (grev)
Air Flow Sensor Voltage (V)
AirFuel Correction #1 (%)
AirFuel Learning #1 (%) AF Sensor #1
AirFuel Sensor #1 (AFR)
Commanded AirFuel Ratio (OBD) (AFR)
Coolant Temp. (BC)
Dynamic Ignition Advance* (B BTDC)
Engine Load* (grev)
Engine Load (Calculated) (grev)
Engine Speed (RPM)
Exhaust VVT Advance Angle Right (B )
Exhaust VVT Advance Angle Left (B )
Fine Knock Learning* (B BTDC)
Fuel Injector #1
Feedback Knock Correction* (B BTDC)
Gear No*
IAT Sensor #12 (BC)
Intake Air Temperature (B C)
Injection Pulse Width* (ms)
Intake VVT Advance Angle Left (B )
Intake VVT Advance Angle Right (B )
Learned Ignition Timing (B BTDC)
Mani. Absolute Pressure (psi)
Mani. Relative Pressure (psi)
Mass Air Flow (gs)
Oil Temperature* (C)
Pulse Width (%)
Primary Ignition Timing* (B BTDC)
Primary Wastegate Duty Cycle (%)
Requested Engine Torque* (Nm)
Throttle Opening Angle (%)
SI-Drive Mode (index)
Vehicle Speed (KPH)
Volumetric Efficiency (MAF)* (%)
Coolant Temp. (BC)
Engine Load* (grev)
Engine Speed (RPM)
Fuel Injector #1
Gear No*
IAT Sensor #12 (BC)
Mass Air Flow (gs)
Pulse Width (%)
Vehicle Speed (KPH)
