Blouch Subaru Turbochargers
General related information
Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
A nice turbo for the 2004+ JDM STI with around 400+WHP on tap. Additional mods should include Perrin EBCS, Process West TMIC, ID850 Injectors
Supporting mods should be Subaru WRX/STi Dominator 1.5XT-R Twinscroll Turbocharger
Part Number SUB-1.5XT-R Twin Scroll
Description
Application: Subaru WRX/STi JDM Twin Scroll Turbocharger
Horsepower: 470CHP
Specs
Garrett Ball bearing CHRA
56.5mm Turbine Wheel
71mm XT Compressor wheel
47lbs per min
BPT Twin Scroll Turbine housing
Turbo includes water pipes, oil feed line, and ported exhaust housing.
JDM Twinscroll header, uppipe, downpipe needed for install
Subaru WRX/STi Dominator 1.5XT-R Ball Bearing Turbocharger
A nice turbo for the 2004+ JDM WRX/STI with around 400+WHP on tap. Additional mods should include Perrin EBCS, Perrin EL Header, Process West TMIC, ID850 Injectors
Supporting mods should be Subaru WRX/STi Dominator 1.5XT-R Ball Bearing Turbocharger
Part Number SUB-DOM1.5XT-R
Description
Horsepower: 480CHP
Specs
49lbs per min
8cm or 10cm Exhaust housing available
The Blouch Dominator 1.5XT-R is a little tweak to our already popular Dom 2.5XT-R. (As I have mentioned before, we are never satisfied with status quo and we are always tweaking something). Originally designed for our 2.0L customers in the UK, the Dom 1.5XT-R uses the Garrett GT 56.5mm turbine instead of the full 60mm turbine of the Dom 2.5XT-R. The end result is a slightly quicker spooling turbo while trading off some high RPM horsepower capability.
Beyond the turbine wheel, the Dom 1.5XT-R consists of the same cutting edge turbo technology that you have come to expect from Blouch Performance Turbo: Blouch billet fully-machined closed die forged 49 lb/min XT-R compressor wheel with state-of-the-art aero, our own custom compressor housing machined in-house and designed for improved fitment, Garrett GT ball bearing center housing and Blouch custom 10cm2 turbine housing with adjustable upgrade actuator.
No boost creep worries here with the smaller turbine - our turbine housing and wastegate actuator are designed to work together to ease your tuner's job and provide the flattest possible boost curve. All of this complete with turbo mounting gaskets, oil feed restrictor, braided stainless steel turbo oil feed line, oil drain tube, coolant pipes, banjo bolts and copper washers. Only at BPT!
Subaru WRX/STi Dominator 3.0XT-R Ball Bearing Turbocharger
This is where things gets serious. WIth power well exceeding 450+whp, this is enough for the average drive.
http://forums.nasioc.com/forums/showthr ... ?t=2220345
Supporting mods should be Subaru WRX/STi Dominator 3.0XT-R Ball Bearing TwinScroll/SingleScroll Turbocharger
Part Number SUB-DOM3.0XT-R
Description
Horsepower: 550CHP
Specs
60mm Turbine Wheel
76mm XT Compressor wheel
55lbs per min
At Blouch Performance Turbo, we are never satisfied with status quo. In our opinion, not innovating is equivalent to moving backwards in the performance turbocharger market. With this in mind, Blouch Performance Turbo took another look at the already stellar performance of the Dominator 3.0R and applied state-of-the-art technology to make it even better.
The first thing we did was address turbine inlet pressure with a superior flowing and better fitting turbine housing than the already successful 8cm2 design. We settled on a 10cm2 design that could be applied to both our journal bearing and ball bearing Subaru products. In order to ensure that quality control meets our standards and we have flexibility to serve our customers, the Blouch 10 cm2 castings are machined in-house on our own CNC equipment.
The next area we addressed was compressor performance and the decision was made to apply our already successful fully-machined billet compressor technology to the Dominator 3.0R. The result is a stonger yet lighter compressor wheel that looks awesome, but more importantly outperforms conventional compressor technologies hands down due to superior aerodynamics.
So did we meet our objectives? You bet we did! The new and improved Dominator 3.0 XT-R is unparalleled in Subaru bolt-on performance with quick spool, great boost control for a nice broad flat torque curve and 550 crank horsepower capability while maintaining a standard 2.360" compressor inlet dimension without any compressor surge. Only at Blouch Performance Turbo - don't settle for anything less!
Subaru WRX/STi Dominator 3.5XT-R Full Ball Bearing Turbochar
This is where things gets serious. With power around 500whp, this is enough for the average drive.
Supporting mods should be Subaru WRX/STi Dominator 3.5XT-R Full Ball Bearing Turbocharger
Part Number SUB-DOM3.5XT-R
Description
Horsepower: 580CHP
Specs
Garrett ball bearing CHRA
64mm Turbine wheel
76mm Compressor wheel
Available in 8cm or 10cm exhaust housing
The Blouch Dominator 3.5XT-R our new state-of-the-art 58lb/min fully machined billet "XT-R" compressor wheel in our own 3" inlet bellmouth compressor housing, Garrett GT full ball bearing system, a high efficiency Garrett GT turbine wheel and the new Blouch 10cm2 turbine housing.
So what's the big deal? The new Blouch XT-R billet compressor wheels are simply amazing and outperform traditional compressor wheel aero by producing more horsepower and torque at lower boost pressures. Born and bred in racing development, the Garrett GT turbine and ball bearing system are the mainstay of turbocharger performance. And the new Blouch 10cm2 turbine housing reduces turbine inlet pressure and engine pumping losses to free up additional torque and horsepower. (These turbine housings work so well that customers have bolted them onto our competitor's turbos and significantly increased torque and horsepower). The big deal is a stock location bolt-on upgrade Subaru turbocharger using state-of-the-art technology that supports 580ank horsepower efficiently with fitment that is unparalleled in the industry. Only at Blouch Performance Turbo!
NOTE: The Dominator 3.5XT-R is a bolt-on upgrade that requires a 3" inlet. Blouch Turbo requires TGV deletes to be used with this turbo and strongly recommends an external gate to achieve maximum performance.
Part Number SUB-DOM4.0XT-R Description Application: Subaru
This is where things gets serious. If your aims are just over 500+whp at boost levels around 28+psi, then this is the turbo for you.
Supporting mods should be Subaru WRX/STi Dominator 4.0XT-R Full Ball Bearing Turbocharger
Description
Horsepower: 600CHP
The Blouch Dominator 4.0XT-R features our new state-of-the-art 60 lb/min fully machined billet "XT-R" compressor wheel in our own 3" inlet bellmouth compressor housing, Garrett GT full ball bearing system, a high efficiency Garrett GT turbine wheel and the new Blouch 10cm2 turbine housing.
So what's the big deal? The new Blouch XT-R billet compressor wheels are simply amazing and outperform traditional compressor wheel aero by producing more horsepower and torque at lower boost pressures. Born and bred in racing development, the Garrett GT turbine and ball bearing system are the mainstay of turbocharger performance. And the new Blouch 10cm2 turbine housing reduces turbine inlet pressure and engine pumping losses to free up additional torque and horsepower. (These turbine housings work so well that customers have bolted them onto our competitor's turbos and significantly increased torque and horsepower). The big deal is a stock location bolt-on upgrade Subaru turbocharger using state-of-the-art technology that supports 600 crank horsepower efficiently with fitment that is unparalleled in the industry. Only at Blouch Performance Turbo!
NOTE: The Dominator 4.0XT-R is a bolt-on upgrade that requires a 3" inlet. Blouch Turbo requires TGV deletes to be used with this turbo and strongly recommends an external gate to achieve maximum performance.
