XRT Hydramist Kit
- west_minist
XRT Hydramist Kit
Water Level = Illuminates when water level is low. Pump will be turned off
Flow = Shows flow from water flow sensor
B = Illuminates when Hydra Auxiliary Maps are enabled
SC = Adjusts the range of flow display
WL = Water flow low fault
WH = Water flow high fault
Hydramist Kit
Element Hydramist Kits Include:
- 150W Hydramist Pump with 125psi By-Pass valve
- 22cc Surge Arrestor Assembly
- HSV (High Speed Water Injection Valve)
- Hydramist Waterflow Guage Kit
- Water Level Sensor
- Water Jets, 0.8mm, 0.9mm and 1mm
- Water Tank Adaptor
- Hydramist Wiring Harness
- M8 Tap (For water jet)
- 5M of 6mm High Pressure Water/Methanol Line
- 2M of 4mm High Pressure Water/Methanol Line
- Stainless 100 Micron Filter
- 40A Pump Relay
- Hydramist Wiring Diagram
Cost $800usd
Generic pricing, exclusive of shipping
West_Minist
Subaru Expert Tuner
info@xtremeracingtuning.com
Viciously Tuned, Driven Hard
Subaru Expert Tuner
- west_minist
Re: Hydramist Kit
Its for water injection. In essence, more power, safer running.
Required Installation Tools Not Supplied:
- Assorted Metric Open Ended Wrenches
- Wire Stripper
- Wire Crimper
- Razor Blade
- Drill and Drill Bits
- 17/64 drill bit for M8 tap (M8 tap supplied)
- Screw Drivers
Required Parts Not Supplied:
- Zip Ties
- 16 ft 8 Gauge Wire (Recommendation: Car Stereo Amp Wiring Kit)
- 40 Amp Fuse
- 4 Bolts and 4 nuts
- Wire Stripper
- Wire Crimper
- Razor Blade
- Screw Drivers
- Zip Ties
- 40 Amp Fuse
West_Minist
Subaru Expert Tuner
Subaru Expert Tuner
- west_minist
Re: Hydramist Kit
This unit can be run without the Hydra EMS, using a boost switch.
West_Minist
Subaru Expert Tuner
Subaru Expert Tuner
- west_minist
Element Hydramist Water/Methanol Injection System Installati
Element Hydramist Water/Methanol Injection System Installation Guide
- Attachments
Element Hydramist Water_Methanol Injection System Installation Guide.pdf
- (655.17 KiB) Downloaded 734 times
