Owner: BartoszB
Rom: D2ZS002E
Tyres: 205/50-17
Car Weight: 1525kg
Driver Weight: 70kg
Total Weight: 1595kg
- Rotrex C38-81
- 65mm Pulley
- Stock MAF mounted in 76mm pipe before SC
- 550x230x65mm Intercooler: http://fmic.pl/jednostronne/279-interco ... x65mm.html
- Cone filter
- Supertech 8.5:1 Pistons
- 76mm piping before SC, 63mm after (incl. IC)
- MAP mounted in stock place in intake manifold
- OEM Subaru Dump Valve (from Forester turbo), return pipe goes into pipe just before SC but after MAF
- Deatschwerks DW200 fuel pump
- STI Pink injectors
- Full (headers&catcack) custom 2.25" exhaust with 2 Magnaflow CATs
Weather data
Addition - https://www.wunderground.com/cgi-bin/fi ... CZKO3&MR=1
BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tuning
Rotrex C38-81
Power: 220-485kw (300-660hp)
Max Flow: 0.58 kg/s (1004CFM) (77lb/min)
Max Presure Ratio: 2.85
- Attachments
- Rotrex C38-81.png (99.42 KiB) Viewed 12861 times
Re: BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tun
Good news. All leaks been sorted and MAF tubed changed from 76mm to 80mm.
In addition, the broken vacuum line to the Fuel Pressure Regulator was fixed. Idle is currently stable and correction perfect to this setup.
Re: BartoszB - 2004 EDM Subaru Outback H6 3.0R 5EAT - SC Tuning
Engine rebuild.
- Attachments
- IMG-20170423-WA001.jpg (136.82 KiB) Viewed 14137 times
- IMG-20170423-WA002.jpg (183.73 KiB) Viewed 14137 times
- IMG-20170423-WA003.jpg (188.27 KiB) Viewed 14137 times
- IMG-20170423-WA004.jpg (144.13 KiB) Viewed 14137 times
- IMG-20170423-WA005.jpg (162.04 KiB) Viewed 14137 times
- IMG-20170423-WA006.jpg (183.88 KiB) Viewed 14137 times
Fresh logs are in and we are slowly getting back on track.
Transmission update
Stock EUDM Legacy H6 MY07
TG5C7CVAAA
FD: 3.583
TG5C7CVAAA
FD: 3.583
Tyres: 245/45r18
Last dyno and we are at 380whp, but awaiting further logging, but the car been delivered to the owner on his B'day!
