RandyM - 2017 USDM XV CVT Turbocharged (XRT-XVT01)
2010+ Subaru CVT 2.5i
Subaru Impreza FB/FA
Subaru Crosstrek
Subaru XV
Rmmotorworks
Re: RandyM - 2017 USDM XVT CVT Turbocharged
Post by Rmmotorworks »
turbo drain sump vent can be teed into Mishimoto crank case vent hose (supplied with intercooler kit). right behind the AC compressor. you can see it in one of the previous photos.
I bought a OEM 15+WRX air box and pipe but the mass airflow sensor did not fit in the WRX box, so I flipped the XV air box up side down and attached it to the WRX turbo inlet pipe, it works but I plan on fabing a custom intake in the future. They sell aluminum mass air flow bungs on ebay, XV is same as STI just not WRX
Rmmotorworks
Rmmotorworks
I used a GFB recirculating valve for a 15+ WRX and it installed as it would on the WRX. I ran the vacuum hose to the plugged port on the intake manifold
Rmmotorworks
a little bit of trimming had to be done to the bumper cowl and behind the fog light covers to fit front bumper cover back on
Rmmotorworks
Sooooo.
the parts list is as follows
used exhaust manifold 180
used turbo 200
Mishimoto FMIC 1050
GFB blow off 180
OEM intake tube 85
440 cc injectors 100
PRL turbo flange 30
oil cap 13
electric oil pump 245 (dont go cheap)
heat wrap 20
exhaust parts 350
02 extender harness 18 x3
WRX PCV valve 19
WRX spark plugs 37
silicon hose for charge 20
transcooler 35
Tactrix cable 170
Innovative PSB-1 265 (SCG-1 is recommended - XRT)
Omni 3 bar map (BRZ) 93
Turbosmart WG 90
misc hosses and fittings 120
fuel pump 160
grand total 3521 + alot of beer
You will also need XRT tuning, but that price is for ed to discuss
all parts were purchased from ebay xept the waste gate, I got a deal on it
Rmmotorworks
Now the car is running great. I have made some decent pulls to collect data for ED. He is doing an outstanding job!!! This is the first time anyone has tuned a 15+ NA for turbo and there are a lot of hurdles to overcome. ED is knocking it out of the park. Every time he sends me a ROM it gets better and better. His CVT tune is awesome, makes it feel like a sports car not a grocery getter.
thank you for looking and keep an eye out for updates
Re: RandyM - 2017 USDM XVT CVT Turbocharged (WRXV)
v3a Boost.png (24.87 KiB) Viewed 23319 times
v3a 3rd Gear Dyno SAE.png (32.64 KiB) Viewed 23319 times
Rmmotorworks
Going to put more boost in it today :D We will see what it does
v7_2a 2nd Gear Dyno SAE.png (76.63 KiB) Viewed 23157 times
Video
