GerryM - 2004 JDM Subaru Legacy 2.0GT 5EAT - Tuning
User avatar
Post by west_minist » Sun Aug 03, 2014 4:34 am
Owner: GerryM
Rom: A2ZJD02A
Tyres: 215/45-17
Car Weight: 1460kg
Driver Weight: 82kg
Total Weight: 1542kg
STI Genome Axle-back box
Cosworth panel filter
Kinugawa Billet Turbocharger SUBARU 06-07 Legacy Liberty TD04HL-20T Twin Scroll
  • Application
    - 06~07 BP5 / BL5 Legacy Liberty GT
    - Replace VF38, VF44, VF45
    - 20T billet wheel + 9 blade turbine wheel will spool fast and offer extra 10% extra airflow to get more HP.
    Bearing Type
    Journal Bearing / Performance Thrust Bearing Kit with larger thrust ring and flinger.
    Cooling System
    Water cooled
    Compressor Wheel
    47/58 mm (20T / 11 Blade Billet Wheel)
    Turbine Wheel 46/58 mm ( TD04HL / 9 Blade High Flow)
    Turbine Housing
    Twin Scroll 8.5cm Housing
    Wastegate Actuator
    - 1.0 Bar / 15 psi
    - 0.5Bar, 0.8 Bar, 1 Bar, 1.2 Bar, 1.5 bar actuators are available, please contact us if you need it.
User avatar
V0 Tuning feedback
Post by west_minist » Sat Nov 22, 2014 1:33 pm
XRT v0 vs Stock Tuned.png (81.36 KiB) Viewed 3681 times
Wg actuator needs setting including checking for intake system leaks.
