EcuEdit/SubaruEdit Logger
Information related to tuning
2015+ 3.6 Legacy/Outback
AirFuel Ratio S1 E1 (OBD) (AFR)
AirFuel Ratio S5 E1 (OBD) (AFR)
Ambient Air Temperature (OBD) (C)
Commanded AirFuel Ratio (OBD) (AFR)
Engine Oil Temperature (OBD) (C)
Engine coolant Temperature (C)
Engine Speed (OBD) (RPM)
Ignition Timing (OBD) (BTDC)
Intake Air Temperature (OBD) (C)
Long Term Fuel Trim B1 (OBD) (%)
Long Term Fuel Trim B2 (OBD) (%)
Mass Air Flow (OBD) (gs)
Manifold Absolute Pressure (OBD) (PSI)
Relative Accelerator Pedal Position (OBD) (%)
Short Term Fuel Trim B1 (OBD) (%)
Short Term Fuel Trim B2 (OBD) (%)
Throttle Actuator Control (OBD) (%)
Vehicle Speed (OBD) (KPH)
2015+ SubaruEdit 2.0/2.5i Impreza/XV/Legacy
A/F Sensor #1
Accel. Opening Angle (%)
Air Flow Sensor Voltage_ (V)
Ambient Temperature (BC)
Coolant Temp. (BC)
Engine Speed_ (rpm)
Intake Air Temp. (BC)
Ignition timing adv. #1 (B)
Knocking Correction (deg)
Learned Ignition Timing_ (deg)
Long term fuel trim B1 (%)
Mani. Absolute Pressure (PSI)
Mani. Relative Pressure (PSI)
Mass Air Flow_ (g/s)
Oil Temperature (BC)
Relative Accelera. Pos. (%)
Relative Throttle Pos. (%)
Short term fuel trim B1 (%)
VVT Adv. Ang. Amount L (deg)
VVT Adv. Ang. Amount R (deg)
Vehicle Speed_ (KPH)
Return to “Tuning Configuration Information”
